MFK2020's avatar
MFK2020
Night Hawk M1 4G signal cutting and not connecting back
Hi all,
Just had a new M1 for a week now ( it's my third one ) , I'm facing a strange problem , the 4G is cutting and not coming back in the night only  , I have to remove the sim card and restart the modem to get it work again.
I have another M1 which work properly when the other having problems.
My firmware version is 12.06.08.00,
The modem is connected to a 4g antenna and the last two nights here are very humid.
Thanks in advance for the support
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi MFK2020
    Welcome to NETGEAR Community!
    Have you tried factory resetting the device?
    Please check if you have WiFi standby set to Enabled. Kindly do the following:
    Access UI > Settings > Setup > Wireless > change WiFi Standby to Disabled.
    Blanca
    Community Team
