sasan89
Nov 06, 2019Aspirant
Night Hawk M1 MR1100 Telstra firmware version stuck at 12.06.02
Hello,
I have the Telstra Model, and it's stuck at 12.06.02 version (no updates yet). I check the community and it seams all other models are either upgraded to 12.06.07 or 12.06.08 which solves the problematic charging algorithm.
I have a third party charger which charges the device a little faster but when it reaches 45 degress Celsius, the device stops charging for a long time and go to battery heat mode. It happens too frequently and it takes so long to charge the device that it's frustrating. I checked and seems the problem is solved in newer firmwares, but for some reason telstra model didn't get the update.
Can I ask for the update?
Thank you,
Sasan Moshirabadi.
- JohnPengNETGEAR Expert
Telstra upgrade is coming soon. The latest upgrade was postponed due to data usage issue on Telstra network. We are helping to address the data usage issue and will have an official release out soon.
