riggy30
Feb 14, 2020Initiate
Night Hawk M1 stopped connecting to t-mobile network
Recently lost connection to the T-Mobile network and it's been working almost perfectly for the last year... Switched sims, updated the firmware, factory reset, changed every setting imaginable on the modem and I still can't get connectivity. Does anyone know if something changed on the network side that's causing this issue? Is anyone else using t-mobile and having similar issues? I just ordered a different netgear lte modem (LB1120) that should be here tmr just to verify if it's a mechanical issue or coming from the network side. I've had some issues with the M1 rebooting itself quite frequently so I'm starting to think it just took a **bleep**. I really don't know what else to do. Any suggestions?
well, looks like the IMEI for the M1 got blocked from the network... used DC unlocker and changed the IMEI and now I have data.
- riggy30Initiate
- thomasjoyceInitiate
What is DC unlocker? i have the same issue and i'm using mac. How to change the imei on the m1 device?
