Taishin
Dec 07, 2022Guide
Night hawk M5 & patch panel
Hi, Is there a fundamental reason why I cannot connect à Nighthawk MR2500 to a patch panel through an RJ45 on the tethering plug? It does not work. Is it only because my patch panel is old (D-link ...
- Dec 10, 2022
If that resolved it, you might mark it solved so others aren't still trying to fix it.
glad it works again!
Dec 07, 2022Guru - Experienced User
Do you mean the MR5200?
You should be able to connect a switch to it.
The one you listed is a pretty simple 10/100mbps unmanaged switch.
Do devices work if directly plugged into it?
- TaishinDec 07, 2022Guide
Sorry, yes MR5200. Devices do work when tethering directly on the mobile router.
- plemansDec 07, 2022Guru - Experienced User
have you tried a different switch?
How many devices are connected?
I don’t have another switch to try… There are 5 devices.
I circumvented the problem by using WiFi on all the devices (no longer need the switch). However our printer doesn’t have WiFi so I connected it to the tethering plug of the mobile router. It didn’t work because the printer had a fixed IP address. The mobile router apparently cannot handle that (strange behavior because ping was ok but not printing). So I changed the printer setting to automatic IP address and use its DOS name when configuring the printer on the PCs.
But when I tried before with the switch, the printer was connected to the switch with a fixed IP address. I did not think the problem could come from that at the time. Maybe it was blocking the whole thing? Doubt it though.
I will try again the mobile router + switch setting without the printer and also with the new printer setting.
Thanks for your help.
