Taishin
Dec 07, 2022Guide
Night hawk M5 & patch panel
Hi, Is there a fundamental reason why I cannot connect à Nighthawk MR2500 to a patch panel through an RJ45 on the tethering plug? It does not work. Is it only because my patch panel is old (D-link ...
- Dec 10, 2022
If that resolved it, you might mark it solved so others aren't still trying to fix it.
glad it works again!
