galvesribeiro
Apr 24, 2023Tutor
Night hawk m6 mr6150 error
Hello folks! Just got my brand new Nighthawk M6 5G unlocked hotspot (MR6150) from Netgear store on Amazon (https://www.amazon.com/dp/B0BGV79FHT?ref=ppx_yo2ov_dt_b_product_details&th=1). The initial ...
JohnPeng
Apr 24, 2023NETGEAR Expert
Please check your APN setting. I think you are using AT&T IPad data plan. You need to set the APN following the link below.
https://www.att.com/support/article/wireless/KM1062162/
You can also send me a model.json log to check further. You can send the file via PM.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
Thanks
- galvesribeiroApr 24, 2023Tutor
I'm not using the ATT APN. My carrier is Claro from Brazil. It works on both my iPhone and iPad where both where purchased in USA and they both works fine with the same SIM card.
I've shared with you a OneDrive link with the JSON file in it. It is too big for the PM.
Thanks!
- JohnPengApr 24, 2023NETGEAR Expert
Thanks!
Please send the model.json file to my email at jopeng@netgear.com. The one drive link didn't work somehow.
Thanks
John
- galvesribeiroApr 25, 2023Tutor
Sent! Thank you.
