TomNormandiePI
Jul 11, 2022Aspirant
Nightawk M1: strange, lost connexion
Dear all, I bought a new Nightawk M1. Set-up OK : M1 used as router with WiFi off and connected to switch with cable then to a Wifi router. I set also ethernet sleeping: never. Both from my laptop...
binitafelicity
Internet connection has been very unstable. It works fine and suddenly all connections (like HTTP, HTTPS) stop working, I'm unable to navigate ...
Connected direct to my laptop cps test via ethernet I get a 4g provided IP and all is dandy. Stable connection, no packet drops after running a continuous ping to 8.8.
After an undeterminable amount of time I lose connection. I haven't tried restarting my Modem yet, it's just odd that everything would be ...
TomNormandiePI
Jul 12, 2022Aspirant
Any solution?
i'll try to test a ping tool to catch when i lose connection?
- TomNormandiePIJul 14, 2022Aspirant
Good news.
Issue seems common according this.
Now, i know what is issue.
I can't both charge M1 and use Ethernet else Ethernet standby.
I must check how can i charge not all time even if "Ethernet standy" set to "disable", it doesn't work: to be confirm.
I'll add comment when more information following tests.
