madhatt30
May 05, 2021Follower
Nighthawk® AX4 4G LTE Modem + WiFi 6 Router
Nighthawk AX4 4G LTE Modem + WiFi 6 Router I run a DNS server on the local network and after spending over an hour with chat support I still couldn't get the concept of the DNS across to the other p...
antinode
May 05, 2021Guru
None of that is a model number. Look for "Model" on the product
label. "LAX20"? Firmware version?
> Yes the firmware is updated to the latest version.
As always, an actual version number would be more useful than your
opinion of what's "latest" today.
https://community.netgear.com/t5/x/bd-p/aircard
> [...] You can not use a local IP address for the DNS server in the
> router. [...]
What happens when you try?
"can not" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] If I try to put the IP address in the router under use custom
> dns it doesn't work. [...]
"doesn't work"? See "not a useful problem description [...]", above.
