Warhascome
May 04, 2020Guide
NIGHTHAWK® M1 MOBILE ROUTER (MR1100) working on Sprint Network
Moving to a Rural area, and this modem seems like a good choice. But will it work on the Sprint network as it's predicessor did not? Thanks. Warhascome
- May 06, 2020
Sprint will not be supported.
nomad247
May 12, 2020Tutor
Got mine to work perfctly on Verizon today, using a tracfone APN setup, and when i shut it off to go back to my ATT sim card, it actually saved my settings, Worked great. Yopu do have to add the APN setup before it will work.
