Warhascome
May 04, 2020Guide
NIGHTHAWK® M1 MOBILE ROUTER (MR1100) working on Sprint Network
Moving to a Rural area, and this modem seems like a good choice. But will it work on the Sprint network as it's predicessor did not? Thanks. Warhascome
- May 06, 2020
Sprint will not be supported.
nomad247
May 12, 2020Tutor
Understood, I feel that was about ATT. I was using a third party sim, like tracfone and pagerlus cellular. Both of these are piggy backing off the big name carriers, offer plans at a cheaper rate. I doubt verizon itself would allow my router which is custome made for ATT. I just did not buy it from ATT so it is not "branded" by ATT. This thought was for you to try one of these third party vendors. I am pretty sure they provide for which ever carrier you tell them you want, like straight talk from walmart. Straight talk comes with three sims cards, you use the one for the carrier you want. I was just saying that the tracfone I tested today, ran off verizon networks. I live rurally as well and only two work out here, ATT and verizon. Personally, I detest ATT, wanted to know if my router work work on verizon, and it did via a tracfone sim. The only other thing I can add is once I setup the APN settings for tracfone, it worked. I would guess that you could buy a cheap plan for tracfone on Sprint and setup the APN and test it. What I entered was tracfone.vzwebt (APN) mobile broadband (APN name), for PDP I used ip4ip6. for PDP roaming I used ip4, none for authentiction. Would guess for Sprint it would be tracfone.spwebt, or what ever the 2 character disignation is for sprint, probably the rest is the same . This plan is 50 a month if auto-pay, 55 if not autopay. Would be worth it to buy a cheap plan, add the APN settings and see if it works. Would go to advanced > cellular, and ADD the new APN stuff. They sell these plans on EBay, been using ATT for 10 months then the supplier decided to raise his price, cancel service that was already paid for to force his cstomers into the higher price, from 49.99 to 79.99. I got a refund after trying to get him booted off ebay, just buy cheap at first to test it. I went with another resellar at a higher price, wanted to test verizon on my router and it worked, under a tracfone sim plan. Probably going with the tracfone next month. My whole point of posting about this was others here said it MIGHT work but would not save the APN settings so would have to re-enter them every time I booted the router. That turned out to be wrong, settings remained. Is food for thought. It workeed for me and saved the settings, wghich in these forums, they said would not save them. Worth a shot.
Warhascome
May 15, 2020Guide
nomad247 wrote:Understood, I feel that was about ATT. I was using a third party sim, like tracfone and pagerlus cellular. Both of these are piggy backing off the big name carriers, offer plans at a cheaper rate. I doubt verizon itself would allow my router which is custome made for ATT. I just did not buy it from ATT so it is not "branded" by ATT. This thought was for you to try one of these third party vendors. I am pretty sure they provide for which ever carrier you tell them you want, like straight talk from walmart. Straight talk comes with three sims cards, you use the one for the carrier you want. I was just saying that the tracfone I tested today, ran off verizon networks. I live rurally as well and only two work out here, ATT and verizon. Personally, I detest ATT, wanted to know if my router work work on verizon, and it did via a tracfone sim. The only other thing I can add is once I setup the APN settings for tracfone, it worked. I would guess that you could buy a cheap plan for tracfone on Sprint and setup the APN and test it. What I entered was tracfone.vzwebt (APN) mobile broadband (APN name), for PDP I used ip4ip6. for PDP roaming I used ip4, none for authentiction. Would guess for Sprint it would be tracfone.spwebt, or what ever the 2 character disignation is for sprint, probably the rest is the same . This plan is 50 a month if auto-pay, 55 if not autopay. Would be worth it to buy a cheap plan, add the APN settings and see if it works. Would go to advanced > cellular, and ADD the new APN stuff. They sell these plans on EBay, been using ATT for 10 months then the supplier decided to raise his price, cancel service that was already paid for to force his cstomers into the higher price, from 49.99 to 79.99. I got a refund after trying to get him booted off ebay, just buy cheap at first to test it. I went with another resellar at a higher price, wanted to test verizon on my router and it worked, under a tracfone sim plan. Probably going with the tracfone next month. My whole point of posting about this was others here said it MIGHT work but would not save the APN settings so would have to re-enter them every time I booted the router. That turned out to be wrong, settings remained. Is food for thought. It workeed for me and saved the settings, wghich in these forums, they said would not save them. Worth a shot.
Thanks for the input.
Reason I was asking about Sprint is I am grandfathered in with them, and the plan I have is $30 a month, unlimited data, and NO THROTTLING.
So for me to be able to use the box with them would be pretty good. Right now, I have a sim card in my Samsung Pad they coaxed me into.
It is paid off, but still have the sim. So I am guessing, if I put it into it, and use the an APN that works, it would work.
I do see these on Alibab for about $150, and they are unlocked, which I am guessing it is not attached to any carrier.
I have seen some on there that say they won't work in the US also. So have to really pay attention.
Friend bought the previous version from Amazon but was locked to ATT.
Won't work for me as ATT sucks out there. Need to use Sprint.
