mrsjlb
Jul 15, 2022Aspirant
Nighthawk 2100. Can i connect a wireless router to extend range,
Nighthawk 2100. Can i connect a wireless router to extend range. Jean
Jul 15, 2022Guru - Experienced User
not sure what the nighthawk 2100 is as it isn't a model number.
but any of netgears router should be able to have an extender connected to it.
You can even connect an extender to their mesh systems but it just doesn't integrate with the system.
- mrsjlbJul 15, 2022Aspirant
Hi the model is a netgear Nighthawk M2100 mobile router
Jean
