mrsjlb
Jul 15, 2022Aspirant
Nighthawk 2100. Can i connect a wireless router to extend range,
Nighthawk 2100. Can i connect a wireless router to extend range. Jean
mrsjlb
Jul 24, 2022Aspirant
So Sorry for the late reply. Thank you for all your help. The range on the m2100 is not very good so i wanted to use m2100 as a modem and a wireless router for wifi range
Jean
michaelkenward
Jul 24, 2022Guru - Experienced User
Jean
That shgould be possible, as plemans suggested.
Did you investigate the three option I suggested?
- router plugged into the M2100 in modem only mode
- router in access point mode plugged into the M2100 in modem/router mode
- wifi connection between M2100 and router
Also, there does not seem to be an "M2100" in Netgear's range of modes. So no one can advise you in which option your modem supports.
Perhaps you mean MR2100.
To help you to choose between the options, start by checking the manual
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
