Paul51
Oct 28, 2018Follower
Nighthawk 4g with ts9 external aeria
[ Spoiler ]
Does this have ports for ts9 exrenal arial connections
NETGEAR R7100LG-100EUS Nighthawk AC1900 Dual Band Wireless Wi-Fi Gigabit Cable Router with Built in 4G LTE
is this the best mo...
TeeJay74
Feb 24, 2019Virtuoso
At least in Europe it is found from here:
https://www.fts-hennig.de/antennenkabel/adapter/antennenadapter-nighthawk.html
the_real_KOSH
Feb 24, 2019Star
I need this case to fit my Netgear in my car :)
Adapter
- the_real_KOSHFeb 27, 2019Star
Some crafts :)
With an 1 Giga-POE Splitter and a good Antenna you need lower transmit current and so it work without AKKU
But I have to test it for longer time . I have one Case in Car and one Case in the roof for short Antenna cabels and easy plug and play
