BR03
Aug 27, 2026Tutor
Nighthawk 5G M7 (MH7110) Not recognised by NETGEAR app
I am trying to add my Nighthawk 5G M7 (MH7110) to the NETGEAR app. When I scan the barcode it says “This device is not supported by this app” the router is working and I can connect devices to it but...
- Sep 16, 2026
Hi,
Not sure if you guys have seen the latest iOS release 1.3.1.58 from the Apple App store. Android is 1.3.1.1072.
Hope this helps.
Delta-X
Sep 06, 2026Tutor
Hi, Just to confirm, did you guys started facing the issue on Netgear app after latest app update on or even before that?
Wakeyrich
Sep 06, 2026Aspirant
Hi, I believe it is the latest update that caused the issue, I only purchased the device approx 4 weeks ago and I connected and set it up via the app without any issues then it stopped being recognised by the app about 2 weeks ago
