BR03
Aug 27, 2026Tutor
Nighthawk 5G M7 (MH7110) Not recognised by NETGEAR app
I am trying to add my Nighthawk 5G M7 (MH7110) to the NETGEAR app. When I scan the barcode it says “This device is not supported by this app” the router is working and I can connect devices to it but...
- Sep 16, 2026
Hi,
Not sure if you guys have seen the latest iOS release 1.3.1.58 from the Apple App store. Android is 1.3.1.1072.
Hope this helps.
Reece13
Sep 09, 2026Aspirant
I have an M7 pro with the same issue. I can only set it up via the LCD and not within the NETGEAR app so am also not able to utilise the NETGEAR eSIM capability.
Delta-X
Sep 09, 2026Tutor
Hi. It seems the latest update has issue app connecting to MH7110 model. The upcoming app update will be able to resolve the issue. Meanwhile you can use the web interface for the device as work around
https://kb.netgear.com/000070491/Web-browser-setup-for-the-Nighthawk-5G-M7-portable-WiFi-hotspot
