BR03
Aug 27, 2026Tutor
Nighthawk 5G M7 (MH7110) Not recognised by NETGEAR app
I am trying to add my Nighthawk 5G M7 (MH7110) to the NETGEAR app. When I scan the barcode it says “This device is not supported by this app” the router is working and I can connect devices to it but...
- Sep 16, 2026
Hi,
Not sure if you guys have seen the latest iOS release 1.3.1.58 from the Apple App store. Android is 1.3.1.1072.
Hope this helps.
Sep 09, 2026Guru - Experienced User
What app version do you guys have?
It is not the Netgear nighthawk app. Its the straight netgear app that is the white icon with blue N on it.
I've got that same hotspot and it connects to my app fine. version 1.4.0.1092
- Delta-XSep 09, 2026Tutor
Hi,
I just downloaded the Netgear App not the Netgear nighthawk app. The latest version is v1.3.1.1072 and on Apple app Store is how's as v1.3.0
What device you are using apple or android?
Where did you download or update the from ?
- BR03Sep 09, 2026Tutor
iPhone and NETGEAR app download from a link sent by NETGEAR support that leads to Apple App Store which is v1.3.0…..where do you get the v1.3.1 version.....?
Where did you get that version from..... I have the NETGEAR only app but can only find v1.3.0
- FortraSep 11, 2026Luminary
@ BRO3, You're correct the version that is available on the OS Apple store is v1.3.0 !
As for Android users you'll have get yours from the Google Play store it doesn't say, what the version is !
To simplify things so you know what to look out for when you went to the download store for the Netgear app. I have included a picture below!
Please note!
I'm not sure if this mobile router hardware version is for Austria or Australia ?
- svetaketuSep 16, 2026Luminary
Hi,
MH7110-1TLAUS is a Telstra (Australia) SKU.
