BR03's avatar
BR03
Tutor
Aug 27, 2026
Nighthawk 5G M7 (MH7110) Not recognised by NETGEAR app
I am trying to add my Nighthawk 5G M7 (MH7110) to the NETGEAR app. When I scan the barcode it says “This device is not supported by this app” the router is working and I can connect devices to it but...
  • svetaketu's avatar
    Sep 16, 2026
    Hi,
    Not sure if you guys have seen the latest iOS release 1.3.1.58 from the Apple App store. Android is 1.3.1.1072.
    Hope this helps.
