BR03
Aug 27, 2026Tutor
Nighthawk 5G M7 (MH7110) Not recognised by NETGEAR app
I am trying to add my Nighthawk 5G M7 (MH7110) to the NETGEAR app. When I scan the barcode it says “This device is not supported by this app” the router is working and I can connect devices to it but...
- Sep 16, 2026
Hi,
Not sure if you guys have seen the latest iOS release 1.3.1.58 from the Apple App store. Android is 1.3.1.1072.
Hope this helps.
Delta-X
Sep 09, 2026Tutor
Hi,
I just downloaded the Netgear App not the Netgear nighthawk app. The latest version is v1.3.1.1072 and on Apple app Store is how's as v1.3.0
What device you are using apple or android?
Where did you download or update the from ?
BR03
Sep 09, 2026Tutor
iPhone and NETGEAR app download from a link sent by NETGEAR support that leads to Apple App Store which is v1.3.0…..where do you get the v1.3.1 version.....?
