BR03
Aug 27, 2026Tutor
Nighthawk 5G M7 (MH7110) Not recognised by NETGEAR app
I am trying to add my Nighthawk 5G M7 (MH7110) to the NETGEAR app. When I scan the barcode it says “This device is not supported by this app” the router is working and I can connect devices to it but...
- Sep 16, 2026
Hi,
Not sure if you guys have seen the latest iOS release 1.3.1.58 from the Apple App store. Android is 1.3.1.1072.
Hope this helps.
Sep 09, 2026Guru - Experienced User
What app version do you guys have?
It is not the Netgear nighthawk app. Its the straight netgear app that is the white icon with blue N on it.
I've got that same hotspot and it connects to my app fine. version 1.4.0.1092
BR03
Sep 09, 2026Tutor
Where did you get that version from..... I have the NETGEAR only app but can only find v1.3.0
- FortraSep 11, 2026Luminary
@ BRO3, You're correct the version that is available on the OS Apple store is v1.3.0 !
As for Android users you'll have get yours from the Google Play store it doesn't say, what the version is !
To simplify things so you know what to look out for when you went to the download store for the Netgear app. I have included a picture below!
Please note!
I'm not sure if this mobile router hardware version is for Austria or Australia ?
- svetaketuSep 16, 2026Luminary
Hi,
MH7110-1TLAUS is a Telstra (Australia) SKU.
