BR03
Aug 27, 2026Tutor
Nighthawk 5G M7 (MH7110) Not recognised by NETGEAR app
I am trying to add my Nighthawk 5G M7 (MH7110) to the NETGEAR app. When I scan the barcode it says “This device is not supported by this app” the router is working and I can connect devices to it but...
- Sep 16, 2026
Hi,
Not sure if you guys have seen the latest iOS release 1.3.1.58 from the Apple App store. Android is 1.3.1.1072.
Hope this helps.
BR03
Sep 09, 2026Tutor
Where did you get that version from..... I have the NETGEAR only app but can only find v1.3.0
Fortra
Sep 11, 2026Luminary
@ BRO3, You're correct the version that is available on the OS Apple store is v1.3.0 !
As for Android users you'll have get yours from the Google Play store it doesn't say, what the version is !
To simplify things so you know what to look out for when you went to the download store for the Netgear app. I have included a picture below!
