BR03
Aug 27, 2026Tutor
Nighthawk 5G M7 (MH7110) Not recognised by NETGEAR app
I am trying to add my Nighthawk 5G M7 (MH7110) to the NETGEAR app. When I scan the barcode it says “This device is not supported by this app” the router is working and I can connect devices to it but...
- Sep 16, 2026
Hi,
Not sure if you guys have seen the latest iOS release 1.3.1.58 from the Apple App store. Android is 1.3.1.1072.
Hope this helps.
BR03
Sep 09, 2026Tutor
Where did you get that version from..... I have the NETGEAR only app but can only find v1.3.0
