BR03
Aug 27, 2026Tutor
Nighthawk 5G M7 (MH7110) Not recognised by NETGEAR app
I am trying to add my Nighthawk 5G M7 (MH7110) to the NETGEAR app. When I scan the barcode it says “This device is not supported by this app” the router is working and I can connect devices to it but...
- Sep 16, 2026
Hi,
Not sure if you guys have seen the latest iOS release 1.3.1.58 from the Apple App store. Android is 1.3.1.1072.
Hope this helps.
Delta-X
Sep 06, 2026Tutor
Hi, Just to confirm, did you guys started facing the issue on Netgear app after latest app update on or even before that?
tonyahollister
Sep 27, 2026Aspirant
i think it is because of latest update
