chazzyb
Oct 12, 2020Follower
Nighthawk 5G Mobile Hotspot Pro
How can we extend the signal on the Nighthawk 5G Mobile Hotspot Pro we already have an orbi 50, are they compatiable? Can we bypass the wifi on the nighthawk 5g hotspot or is there a better answe...
JBish
Dec 11, 2020Aspirant
I would suggest getting the antennas for it to broaden range... Believe it uses 2 x TS-9 which mount on back of unit... Under the 2 plugs you see on each corner of device...
