elgoots
Mar 19, 2023Guide
Nighthawk 6 PRO ( MR6500 )
It is very apparent that the MR6500 Nighthawk 6 PRO has some critical issues for people who use them fulltime. Dropping out of signal (says searching) even though you had full reception and other 4...
- Mar 22, 2023
Hi John, I have emailed you with subject: json log for nighthawk 6 pro as requested on forum
saimirgasa
Mar 27, 2023Initiate
Hi John -
I just emailed you my model.json file as well.
I'm also facing interruptions throughout the day. I work from home and I have to remote desktop into a VM for work and as you may guess interruptions can be very problematic. These interruptions have stuck my VM session into an unresponsive state 3 times last week causing me a couple of hours to restart my M6 Pro and my VM.
The other problem that I have is that the whenever I turn on Dual-Band 2.4 & 6 GHz the 6GHz SSID is not discovered. My laptop has 6E enabled as I have connected to other 6GHz band before (not with M6 Pro device).
I have had this device for a little over a week now and I got to say I'm not satisfied due to these problems. If they keep happening for another week or so I will have to return it.
And yes, I have the latest firmware and I have reset the device multiple times.
Looking forward to your response!
Saimir
