Eam_Mpm
Feb 24, 2018Aspirant
Nighthawk AC1900 R6900v2
Nighthawk AC1900 Model : R6900v2 I have followed the start up instructions in the pamphlet and have let the genie set up multiple times . But i still can't get my modem and router to connect and prod...
JasonN
Mar 02, 2018NETGEAR Employee Retired
Hi Eam_Mpm,
I just wanted to check in with you and see if your issue has been resolved.
Please let me know :]
- Jason N
Eam_Mpm
Mar 02, 2018Aspirant
As far as I know it is up to date with the firmware . I'm not sure how to factory reset it though , how do I ?
- JasonNMar 05, 2018NETGEAR Employee Retired
Hi Eam_Mpm,
Please locate the factory reset button located on the back left of the router.
Using narrow enough to fit the whole (a paperclip), press and hold the button for at least 10-15 second.
Release the button and wait for the router to reboot.
Please let me know if this worked. :]
- Jason N
- JasonNMar 08, 2018NETGEAR Employee Retired
Hi Eam_Mpm,
I just wanted to check in with you and see if your issue has been fixed.
- Jason N
- Eam_MpmMar 13, 2018AspirantThe firmware isn't up to date . And I evidently can't update it from my phone . With our old modem we could still connect to the internet with them both hooked up , we just couldn't connect through the router . I guess I'm going to have to get a laptop and try to update the firmware like that .
