JASON1962
May 08, 2023Follower
NIGHTHAWK AX3600-5
I am trying to configure the following system. Netgear M100 hotspot---->netgear GS105 switch-------> Netgear AX3600-5 ------> Netgear MR60---->NetgearMR63 CAt 6 cable connecting everything but I...
CrimpOn
May 08, 2023Guru - Experienced User
Would help to know the product number of AX3600-5 (perhaps from the product label attached to the device).
When I enter AX3600-5 into the Netgear support site, nothing shows up:
https://www.netgear.com/support/
