Ansons
Jan 07, 2024Follower
Nighthawk connection issues with Eufy homebase2.
I am trying to set up my Eufy homebase 2 to Nighthawk M6 however eufy needs an internet cable RJ45 to connect prior to wifi connection. M6 I believe has the RJ45 connection however is only for input a...
Jan 09, 2024Guru - Experienced User
The ethernet port isn't single direction. It should be fine to provide a connection to the eufy. I've got a M6 and tried connecting a switch and a router to its ethernet port without issues.
