southflguy
Apr 07, 2019Star
Nighthawk Defaulting to HSPA+
So I just purchaed a Nighthawk Hotspot for AT&T. All my AT&T devices default to band 66 LTE with speeds up to 100mbps. The Hotspot refuses to connect to this band or any other full LTE band. I am getting only HSPA+. Does anyone know what is going on? Thanks!
1 Reply
I figured it out. For some reason I had to switch to manual nework, select T-Mobile and then the LTE choice came up. Selected that then switched back to AT&T. Strange.
