mctalks
Aug 11, 2022Star
Nighthawk LAX20 and TS9 cellular antenna
I am looking to increase my 4G LTE cellular signal strength and consistency and was wondering if any LAX20 users have had any luck with TS9 antennas and if so, which brand/type? I recently tried a pa...
Alex-
Oct 04, 2022Aspirant
mctalks wrote:ALSO, does using these TS9 antennas require me to disconnect the regular antennas or can I have 4 plugged in at the same time? ( that would be the two that came with the LAX20 and 2 additional TS9 antennas ).
This question is already answered on page 13 of the user manual under the header "Attach and position the antennas". The two WiFi antennas on the side work independently from the LTE antennas on the back.
I also would like to know which LTE antennas others are using...
- liammaccaNov 12, 2022InitiateI am attempting to increase the LTE signal of my LAX20, but am finding the cheap antennas I bought to trial very inconsistent and the connector to be quite loose. I’m tempted to go for the net gear one you described, or even an outdoor unit, but would love to know if anyone has had success with these setups before I spend more money on a solution.
March appreciated,
L
