mctalks
May 24, 2022Star
Nighthawk LAX20 continuously resetting 4G LTE connection: SOLVED...I think
This is for anyone with a Nighthawk LAX20 WIFI 6 router who may be having issues with the 4G LTE connection constantly resetting. As you know, trying to get work done while constantly losing the inte...
mikeadamsnc
Aug 17, 2022Aspirant
Thank you for the suggestion! Every time I opened up my laptop it would cut the 4g (Verizon) on and off as you described above and would not happen with any of my other devices (phones, tablets). I didn't have Kaspersky installed but I had an Endpoint for Malwarebytes running and uninstalling that immediately fixed the problem. I hope this is something Netgear will address in a firmware update as virus protection is a must for most people.
mctalks
Aug 17, 2022Star
I'm glad you were able to solve this most annoying problem as well. I agree with you that Netgear really does need to address this in a firmware update. Speaking of firmware, there hasn't been an update for the LAX20 in quite a while.
Hint, hint....
