computeronix's avatar
computeronix
Apprentice
Apr 03, 2018
Nighthawk LTE - Feature Request - Copy Device Details
On the AT&T Wifi Status Page (inside the router web admin) -> when you select Device tab -> you see a wealth of device details including the firmware version.
Right now using Google Chrome you cannot copy and paste any of the text.
Can you add a feature to be able to copy and paste these details?  It would make it much easier for reporting issues and also getting the information for various use cases.
Current Firmware: NTG9X50C_12.02.06.00
1 Reply
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi computeronix,
    Thanks for inputting another suggestion! I will also forward this to my internal team and see what they would like to do with this. :]
    - Jason N
