computeronix's avatar
computeronix
Apprentice
Apr 03, 2018
Nighthawk LTE - Feature Request - Screen Timeout 15 Seconds
In the Settings -> Advanced -> Device there is a screen timeout drop down box....can you add an option for a 15 second timeout for the screen?  Currently the lowest is 30 seconds
Current Firmware: NTG9X50C_12.02.06.00
1 Reply
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi computeronix,
    I will forward your suggestion to my internal team and see what they want to do with it. Thank you for your suggestion. :]
    - Jason N
