nhantenna
Nov 14, 2017Apprentice
Nighthawk LTE hotspot + external antennas
I am in the United States. I purchased the Nighthawk LTE hotspot directly from AT&T. I have several technical questions about the two external antenna ports on this hotspot. 1) Do the external ant...
TeeJay74
Dec 28, 2017Virtuoso
I'm sorry to note that most people here are almost completely lost with LTE antenna speculations. Netgear cannot know the environment you are using your MR1100. The external antennas are selected based on the radio conditions. Internal 4x4 Mimo antennas are good but if the distance to tower is longer then it may be good to use external mimo antennas. When you connect 2x2 Mimo antennas to MR1100 then internal 4x4 Mimo antennas are disabled. I have reached 600 Mbps download with both internal 4x4 Mimo and external 2x2 Mimo so both antenna solutions can give equally good performance. If you are using MR1100 in urban/city area then it is absolutely worth to try two external omni directional mimo antennas in 90 degrees angle because omni mimo can utilize signal reflections better than internal 4x4 mimo antennas.
tobys
Feb 02, 2018Aspirant
Hey TeeJay.
Thanks for the very useful info.
I'm in the UK and have a signal issue inside but have found with the M1100 outside and at about 3m high I get good throughput.
Can you advise what 2x2 external omnis you are using please? I'm familiar with 2.4G & 5GHz antennae but not LTE.
Thanks again!
Toby
Thanks again!
Toby
- TeeJay74Feb 02, 2018Virtuoso
Hi,
When I use outdoor 2x2 Omnis this is my choice: REN 66008X ODN (CSG Networks), 2 units required when using MIMO.
- UK-basedFeb 03, 2018Luminary
I'm also in the UK with EE as my carrier. I'm using this external antenna from Poynting, which is actually a dual-polarised omni-directional antenna in one housing (price in the UK around £77.50), with 2 cables and SMA connectors (requiring 2 pigtail SMA to TS-9 adapters for connection to the M1). Prior to installing this antenna I had 2-3 signal strength bars on the M1, which increased to 5 bars after installation. The best download speed on a wired connection has been 90Mbps. I'm in a rural location about 3.5km from the mast.
The specs. for the Poynting XPOL-A0001 antenna give gain at 790-960MHz as 1.6dBi and gain at 1710-2700MHz as 4dBi. This is quite a lot less gain than the CSG Networks 66008X ODN that you recommended, TeeJay74, which is quoted as offering 6.0dBi gain at 698-960MHz and 8.0dBi at 1710-2700MHz. After a quick search, I couldn't find a UK supplier for this antenna but here's a similar CSG antenna on Amazon with gain of 4-5dBi, costing £88.37. And here's a similar Poynting antenna with 5-6dBi gain for £109.32. In both cases it would be necessary to buy 2 of these, costing a total of between £176 and £218. So the increased gain obviously comes at a price.
TeeJay74, if the 2 separate antennas were used, how should they be oriented for the UK's EE carrier, and what would the best separation be? Would one be mounted vertically and the other horizontally? I guess the latter could end up with water ingress. What about one at 45 degrees from vertical and the other at -45 degrees from vertical? What separation in this case?
- TeeJay74Feb 03, 2018Virtuoso
What makes omni antennas special, is their ability to utilize signal reflections more effectively than other antenna types. If your surroundings have lot of hard material surfaces then there are lot of reflections. Using them can provide some extra speed. Then antenna oriéntation thing.
I have tested -45/+45 , horizontal/vertical and both vertical orientation setups. Theorist say for Mimo, orientation should be exactly 90° between antennas. When signal reflects there is almost certainly some twist and bend. However, vertical/vertical setup can provide almost similar performance. So I suggest it may not be worth to put too much attention to this omni orientation thing, because vertical/horizontal vs vertical/vertical can provide almost equal performance. Some day v/h is better, other day v/v can be slightly better. When I tested MR1100 and good table omni mimo in car setup, speed differences were 10-30 Mbps when orientation changed. That was very small difference, because my download was about 500 Mbps that time. Only one thing needs more investigation and that is separation distance between outdoor omni antennas. Probably 50 cm would be good, I guess.
