nhantenna
Nov 14, 2017Apprentice
Nighthawk LTE hotspot + external antennas
I am in the United States. I purchased the Nighthawk LTE hotspot directly from AT&T. I have several technical questions about the two external antenna ports on this hotspot. 1) Do the external ant...
UK-based
Feb 03, 2018Luminary
Thanks TeeJay74 for your very informative answers :smileywink:
Regarding a good table omni mimo antenna, do you have any suggestions?
TeeJay74
Feb 03, 2018Virtuoso
Hi,
I am using this model:
of course equivalent models do exist.
- UK-basedFeb 04, 2018Luminary
Have you ever tested a portable antenna like this one, TeeJay74? Here's a guy stripping apart something that looks similar externally. The contents of the antenna in the first link could be completely different - I certainly don't want to negatively influence its sales. But is it likely that the apparently simple design of the stripped down version would ever offer an improvement over the internal antennas in the M1?
- TeeJay74Feb 04, 2018Virtuoso
Hi,
I have that Panorama antenna and I am not impressed with its performance.
Thanks TeeJay74 - I won't be tempted by one :smileyvery-happy:.
