nhantenna
Nov 14, 2017Apprentice
Nighthawk LTE hotspot + external antennas
I am in the United States. I purchased the Nighthawk LTE hotspot directly from AT&T. I have several technical questions about the two external antenna ports on this hotspot. 1) Do the external ant...
AndyR71
Feb 22, 2018Tutor
Hi All, I just posted a question about whether you need to change any settings after connecting an external antenna to the Nighthawk M1?? I've looked around the admin settings and can't see where you would and nobody seems to mention this on other threads and youtube clips. Can someone let me know if it just auto detects or what? - Thanks !!
TeeJay74
Feb 22, 2018Virtuoso
No need to change anything from webgui. It is auto detection.
- AndyR71Feb 22, 2018Tutor
Thought so but many thanks for confirming. :-)
- KarmusDKMay 08, 2018Apprentice
TeeJay74 When you talk about "2 units" of MIMO antennas, do you mean one MIMO antenna with two cable outputs, or do you mean physically two antennas with four cable outputs, that are combined in a split cable in each of the TS9-ports?
- TeeJay74May 08, 2018Virtuoso
I had to check that earlier text what was it. I think it was that omni antenna talk. MR1100 has two visible external antenna connectors and that CSG omni antenna has one connector so two GSG omni antennas(2 cables) required to reach 2x2 mimo effect.
