nhantenna
Nov 14, 2017Apprentice
Nighthawk LTE hotspot + external antennas
I am in the United States. I purchased the Nighthawk LTE hotspot directly from AT&T. I have several technical questions about the two external antenna ports on this hotspot. 1) Do the external ant...
AndyR71
Feb 22, 2018Tutor
Thought so but many thanks for confirming. :-)
KarmusDK
May 08, 2018Apprentice
TeeJay74 When you talk about "2 units" of MIMO antennas, do you mean one MIMO antenna with two cable outputs, or do you mean physically two antennas with four cable outputs, that are combined in a split cable in each of the TS9-ports?
- TeeJay74May 08, 2018Virtuoso
I had to check that earlier text what was it. I think it was that omni antenna talk. MR1100 has two visible external antenna connectors and that CSG omni antenna has one connector so two GSG omni antennas(2 cables) required to reach 2x2 mimo effect.
- AmphybiouSJun 11, 2018AspirantHi guys, I need to increase signal strength for my M1100 installing externals antennas outside my house.
I'm near the tower approximately 1km. Do you suggest directional or omnidirectional antenna?
How many antennas I need? 1 or 2 mimo? If I take 1 MIMO, can have only 2x2 isn't? If I take 2 antennas, I have to use a pigtail to connect 2 cable from one antenna in first ts9 of the router, same for the second antenna. Isn't?
Thanks!- nhantennaJun 14, 2018Apprentice
if your nighthawk is switching between towers in different directions you want omni. you only want directional if you are too far away for omni to work. this depends on your location. different towers have different power output, heights, etc. if your cell phone works standing on your roof, your nighthawk will work.
How many antennas I need?you only need one antenna. you do not need to connect anything to the second antenna port on the nighthawk.
netgear does NOT disclose how antennas work on their product. you just have to experiment. in the last year, i have NEVER seen anyone post that a second external antenna improved their download/upload speeds.
one antenna into one nighthawk antenna port. do not split/combine anything. if you want to add a second antenna, the second antenna is plugged directly into the second nighthawk port.
- AmphybiouSJun 17, 2018AspirantI have a LTE Antenna 14dbi gain, with 2 cable with SMA connector going in the modem. So, I have to find a connector that convert 2 SMA into one TS9 isn't? I already have 2 convertor SMA into TS9 and actually connected into the 2 Nighthawk ports. It works, not very well but works.
Thanks.
