nhantenna
Nov 14, 2017Apprentice
Nighthawk LTE hotspot + external antennas
I am in the United States. I purchased the Nighthawk LTE hotspot directly from AT&T. I have several technical questions about the two external antenna ports on this hotspot. 1) Do the external ant...
nhantenna
Jun 14, 2018Apprentice
Do you suggest directional or omnidirectional antenna?
if your nighthawk is switching between towers in different directions you want omni. you only want directional if you are too far away for omni to work. this depends on your location. different towers have different power output, heights, etc. if your cell phone works standing on your roof, your nighthawk will work.
How many antennas I need?
you only need one antenna. you do not need to connect anything to the second antenna port on the nighthawk.
1 or 2 mimo? If I take 1 MIMO, can have only 2x2 isn't?
netgear does NOT disclose how antennas work on their product. you just have to experiment. in the last year, i have NEVER seen anyone post that a second external antenna improved their download/upload speeds.
If I take 2 antennas, I have to use a pigtail to connect 2 cable from one antenna in first ts9 of the router, same for the second antenna.
one antenna into one nighthawk antenna port. do not split/combine anything. if you want to add a second antenna, the second antenna is plugged directly into the second nighthawk port.
AmphybiouS
Jun 17, 2018Aspirant
I have a LTE Antenna 14dbi gain, with 2 cable with SMA connector going in the modem. So, I have to find a connector that convert 2 SMA into one TS9 isn't? I already have 2 convertor SMA into TS9 and actually connected into the 2 Nighthawk ports. It works, not very well but works.
Thanks.
Thanks.
