TTRN
Mar 09, 2018Follower
nighthawk lte mobile hot spot router
I have 2 Nighthawk LTE Mobile Hot Spots Routers, but only one shows up on my wifi managers. Is this normal or OK?
UK-based
Mar 10, 2018Luminary
I've tried to write an extensive answer but for some reason it doesn't post. So I'll give you a quick suggestion - change the default gateway IP address of one of the MR1100s so that they aren't both set to 192.168.1.1, e.g. 192.168.1.2. Remember that once you've changed the address, you will have to use the new address to access its interface using a browser.
- UK-basedMar 10, 2018Luminary
Continued...
If you are using DHCP on both devices or on another router in your network, it's a good idea to set their DHCP ranges so that they don't overlap. For example, the DHCP start address on the one MR1100 could be 192.168.1.10 and the end address could be 192.168.1.130. Then the start address on the other could be 192.168.1.131 and the end address could be 192.168.1.250.
