khairymadhoon
Feb 05, 2018Aspirant
Nighthawk LTE Mobile Hotspot Router Model MR1100 factory unlocked for any GSM provider
Hello, I would like to ask the Netgear developer if the Nighthawk LTE Mobile Hotspot Router Model MR1100 will be available for retail so we can use any GSM SIM Card worldwide, I do appreciate...
- Feb 05, 2018
Hi,
Retail model launch is February. Please just do Google search MR1100-100EUS and you may find some shops which allow pre-ordering.
TeeJay74
Feb 05, 2018Virtuoso
Hi,
- khairymadhoonFeb 05, 2018AspirantThanks Tee.
- UK-basedFeb 05, 2018Luminary
Does that mean that firmware updates for the MR1100 will be made available for "manual" download from the Netgear site, TeeJay74, so that people can update their MR1100 whenever they want, instead of having to rely on auto-updates?
- TeeJay74Feb 05, 2018Virtuoso
I think OTA is going to be the only way.
How do you think that will work in practice? What about the situation where someone buys an M1 in the UK and then wants to use it in the States - would the M1 update its firmware to match the SIM card/carrier being used? Would this mean every time a SIM card is changed, a firmware update might be needed?
