khairymadhoon
Feb 05, 2018Aspirant
Nighthawk LTE Mobile Hotspot Router Model MR1100 factory unlocked for any GSM provider
Hello, I would like to ask the Netgear developer if the Nighthawk LTE Mobile Hotspot Router Model MR1100 will be available for retail so we can use any GSM SIM Card worldwide, I do appreciate...
- Feb 05, 2018
Hi,
Retail model launch is February. Please just do Google search MR1100-100EUS and you may find some shops which allow pre-ordering.
JasonN
Mar 21, 2018NETGEAR Employee Retired
Hi khairymadhoon & Ni_co_las,
It will depend on which provider model you have for the M1 and also if your device is unlocked.
Please let me know. :]
- Jason N
Ni_co_las
Mar 21, 2018Aspirant
Hi JasonN, I will use the MR1100 version EUS (no SIM lock, http://www.netgear.fr/home/products/mobile-broadband/mobilerouters/M1.aspx) and I intend to buy either a AT&T or VERIZON or T-Mobile SIM card (prepaid without plan) during my trip in the US. The point is that the EUS version datasheet does not list all the applicable US Band and I just would like to know if the datasheet is given according to the country where you by the MR1100 but the MR1100 can nevertheless proper function in another country using all the Bands without restrictions due o e.g. firmware Here is the definition of the Frequency given in the datasheet depending on the version - MR 1100 EUS: 700/900/1800/2100/2600 MHz - MR1100 US: 700/800/1700/1900/2100/2300/2500 MHz Thank you. Nicolas
- JSchnee21Mar 22, 2018Virtuoso
Hello Ni_co_las,
I suspect your EUS MR1100 will work just fine. The hotspot is, in reality, no different than a modern multiband phone. The Qualcomm x16 modem and RF headend is the best in the world. This is the same modem found in nearly every higher end mobile phone across the world. The French website you listed, shows the frequencies the MR1100 supports. This lines up very nicely with what is used in the USA. Recently, with the widespread use of LTE, we've stopped referrencing the underlying frequencies as it just got to be too cluttered and confusing for most end users.
Here is the band to frequency mapping for carriers in the USA
You may or may not have issues getting the MR1100 to work on Tmo or Verizon. Tmo uses some "less standard" frequency arrangements (ex. "flipped" transmit/receive blocks) and has somewhat more urban focused coverage map. Verizon's frequency allocations and coverage areas more are similar to AT&T which officially offers the MR1100 but they still use some CDMA as well and offer no 3G/4G -- only LTE. Neither Tmo nor Verizon officially offer for sale or provide tech support for the MR1100
I have a USA version (AT&T) unlocked MR1100 and when I do a manual carrier scan, I can see AT&T, Tmo, and Verizon. AT&T claims I can roam just fine to Europe with my device, though I have not yet tried. One thing to keep in mind, you may have to manually enter the "APN" for your carrier when you insert your pre-paid SIM. I found that when I tried using my Tmo SIM in my MR1100 the APN did not update (it stayed on the AT&T setting).
So, if possible, I would suggest an AT&T pre-paid SIM for your hotspot -- assuming they sell such a thing. I'm a post-paid AT&T customer.
-Jonathan
