Alexp69
Jun 23, 2018Aspirant
Nighthawk LTE mobile router stand by power usage
Hi all,
I want to install an LTE mobile spot serving an IP security cam on a boat where I have no access to shore power save for installing more solar cells. I need to calculate a power budget. I l...
Richard_J
Aug 06, 2018Tutor
I don't think the Netgear nighthawk would provide good solution for your cam recording and heavy download requirement. Better to try other netgear WiFi routers.
Alexp69
Aug 06, 2018Aspirant
My usage is going to be indeed very light indeed...few minutes day/week...
- JSchnee21Aug 06, 2018Virtuoso
Hi Alexp69,
You should assume that the AC to DC charger is the main consumer of power. I'd recommend you buy a good QC2 or QC3 charger (from Anker for example). Like this one:
https://www.anker.com/products/variant/powerport-speed-2-ports/A2025111
Power consumption will vary between 0.5W and ~20W if only a single device is plugged in.
