Alexp69
Jun 23, 2018Aspirant
Nighthawk LTE mobile router stand by power usage
Hi all,
I want to install an LTE mobile spot serving an IP security cam on a boat where I have no access to shore power save for installing more solar cells. I need to calculate a power budget. I l...
Alexp69
Aug 06, 2018Aspirant
My usage is going to be indeed very light indeed...few minutes day/week...
JSchnee21
Aug 06, 2018Virtuoso
Hi Alexp69,
You should assume that the AC to DC charger is the main consumer of power. I'd recommend you buy a good QC2 or QC3 charger (from Anker for example). Like this one:
https://www.anker.com/products/variant/powerport-speed-2-ports/A2025111
Power consumption will vary between 0.5W and ~20W if only a single device is plugged in.
