tcconway's avatar
tcconway
Follower
Sep 20, 2018
Nighthawk LTE Work on Verizon
Hi.
Does the Nighthawk LTE Hotspot work with Verizon (US)? Can I just get a prepaid sim card from them, plug it in and away I go?
Thanks!
  • Good question.  Is your mr1100 unlocked?  If it is the AT&T version you will need to request an unlock code from AT&T.
    In terms of Verizon, it should, but it may or may not work that well.  AT&T and Verizon use many of the same LTE radio bands, but some of their configurations (sub blocks) and CA combinations are different.
    My mr1100 can see both the Verizon and T-mobile networks when I change from Auto to manual network scan.  But, I don't have a Verizon SIM to try.  I do have a tmobile SIM, but honestly haven't tried it (I have unlimited AT&T).
    You will also have to change the APN from the AT&T default to the Verizon APN settings.  I've read some reports that the mr1100 has a bug and doesn't save "non-standard" (aka non primary carrier APN's).  But I don't know if this is true.  If it is, you'd have to re-enter it every time you restarted the hotspot
1 Reply
