traceybaysinger
Mar 25, 2020Aspirant
Nighthawk LTE
Can someone please verify if there is a difference? Im looking for a Netgear Nighthawk LTE. When I search I see the M1100 series. Is this the same or are they different? Thank You for any help ...
JohnPeng
Mar 26, 2020NETGEAR Expert
Please advise how you plan to use the device?
Thanks
- traceybaysingerMar 26, 2020AspirantWe are in a rural area. But cell phones work good. So we are going to use as an internet option to our home
- JohnPengMar 26, 2020NETGEAR Expert
For this case, You have two options:
1. Get MR1100 Retail version on Amazon. Then you can get a mobile hotspot data plan from any carriers that support M1 and have better coverage at your area.
2. Get the AT&T version MR1100 with their data plan. You need to make sure ypu have better AT&T coverage at your home.
Thanks
