lukeko
Aug 21, 2019Aspirant
Nighthawk M1 – Extremely High Data Usage (120 MB Minimum Amount of Data Used Per Connection!)
Hi, Is anyone aware of a solution to reduce the amount of data used per connection on the Nighthawk M1? In reading – and looking at my data logs – the Nighthawk M1 uses a minimum amount of da...
