lukeko
Aug 21, 2019Aspirant
Nighthawk M1 – Extremely High Data Usage (120 MB Minimum Amount of Data Used Per Connection!)
Hi, Is anyone aware of a solution to reduce the amount of data used per connection on the Nighthawk M1? In reading – and looking at my data logs – the Nighthawk M1 uses a minimum amount of da...
lukeko
Aug 26, 2019Aspirant
Hi Blanca_O,
Thanks for your reply.
I already have the billing data from my Carrier showing the multitude of 120 MB blocks used per session (along with their session duration).
The data file is attached (PDF format), ordered by descending Usage (and personally identifiable information removed).
Luke
Blanca_O
Sep 04, 2019NETGEAR Employee Retired
