dawolfman's avatar
dawolfman
Nighthawk M1 - Can ethernet jack run to ethernet router?
Simple question: I have devices that are not wifi. Can I run an ethernet cable from the Nighthawk M1 to an ethernet router, or do I have to use a wifi extender w/ ethernet connection (I have) to cabl...
  • icaruspony's avatar
    Sep 04, 2020
    If you want to use the routing functions/wifi inside the MR1100, then it is best to connect and ethernet switch to the MR1100 instead of a second router.
    If you want a second router instead, then you will disable wifi, dhcp, and ethernet standby in the MR1100 and also set the MR1100 to IP Passthrough and connect the router's WAN port to the ethernet port on the MR1100.
