HannuKop
Mar 29, 2018Aspirant
Nighthawk M1 - Data offloading won't work
Nighthawk M1 LTE Mobile Router, latest firmware (of March 2018), latest Netgeat Mobile App installed. I'm trying to get the data offloading feature to work, with little success. Tested it with two s...
HannuKop
This happens with two separate WiFi routers I'm trying to offload to, but could be. What would be workable alternate gateway IP?
HannuKop
Tiny addition: with wired connection the data offloading works perfectly. I plugged the network cable in and everything worked great right away. WiFi offloading on the other hand....
- UK-basedMar 29, 2018Luminary
Sorry, I didn't see your "tiny addition" before sending my reply. If it works with the wired connection, I have my doubts about a clash with the other router's IP address but you could always check this. There are other more experienced contributors than me who may be able to help you further, such as MicW
- HannuKopMar 29, 2018Aspirant
Hi,
The router indeed has that IP:
- IP Address: 192.168.1.1
- IP Subnet Mask: 255.255.255.0
- DHCP: ServerAnd I presume the other has as well.
But when connected to this router with ethernet cable offloading works, when trying WiFi with the same router I get the error mentioned. But I will try changing the IP.
Thanks!- MicWMar 29, 2018Luminary
Thanks for the vote of confidence UK-based . It looks like you spotted the issue and answered it great :). HannuKop let us know if it works once you get the M1 gateway IP address moved away from the routers address ( I'd also make sure its outside the routers DHCP range too so no other device gets a conflicting IP with the M1).
