WiggyToo's avatar
WiggyToo
Follower
Feb 08, 2022
Nighthawk M1 - loses mobile broadband connection when not used
Hi,
I use this device as a failover on the network if my main fibre is unavailable (not often).
At the moment it works OK, but if left to its own devices it loses the mobile data connection and a reboot is required to restore it.
Anyone have any ideas on why this happens - or any work arounds to keep it awake apart from connecting a smart plug an power cycling it every hour.
Thanks
Gavin
No RepliesBe the first to reply
