Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
JasonN
Apr 03, 2018NETGEAR Employee Retired
Hi Glocknerblick,
Unfortunately, the M1 does not provide the selection of LTE Band/Frequency. This idea has been forward to the internal team and they are looking into it.
Thank you for your post. :]
- Jason N
